Author Topic: Glee/650 std dog bone linkage length  (Read 3201 times)
Offline Hondaman
  • Bike: 650 L3
« on: August 16, 2016, 22:20:21 »
As above, could someone please give me the standard suspension linkage 'dog bone' length - measuring the hole centres. I just want to double check that mine wasn't lowered by the PO.
I have ~44mm clearance between rear tyre & the floor with bike on the centre stand (the forks are droped through ~10mm btw).
My links measure 142/143 mm hole centres.
Ta, Phil
Offline Sam
Re: Glee/650 std dog bone linkage length
« Reply #1 on: August 16, 2016, 22:39:29 »
140mm
Offline Hondaman
  • Bike: 650 L3
« Reply #2 on: August 17, 2016, 06:30:03 »
OK, thank you Sam.
I think that's near enough to confirm that mine are standard.
Cheers Phil
Offline Sam
« Reply #3 on: August 17, 2016, 09:38:19 »
Not necessarily! The ratio is about 3 or 4 to 1. So if yours are 3mm different then that would equate to about 10 to 12mm (or half an inch) difference to the ride height. If I remember correctly, the standard Suzuki links have the part number stamped on them where as aftermarket ones don't. I don't own a v-strom anymore so can't check for you. Maybe someone else (greywolf!) can give more info.
Offline Hondaman
  • Bike: 650 L3
« Reply #4 on: August 17, 2016, 13:00:48 »
Google search shows a few threads on Strotrooper (don't know why I never thought to google first!
As you mention, stock links are 140mm, with a 2.8:1 ratio.
So if my measuring is correct mine coukd be 6-9 mm lower than stock.
I'm sure there are some stamp marks on the rh dog bone. I'll check later.
Offline Hondaman
  • Bike: 650 L3
« Reply #5 on: August 17, 2016, 20:45:14 »
After a proper measure with verniers, it looks like I have stock 140mm links which are stamped '06G'
I might pich up some 20 or 25mm jack up links & put the forks nearer to stock.
