Author Topic: o/d light flashes  (Read 2603 times)
Offline plumber02
  • Bike: DL1000-K8 wr450f
o/d light flashes
« on: August 12, 2016, 18:08:17 »
hi lads I've got a TRE fitted so I've got no o/d light when in 6th but lately on initial start up the o/d light has been flashing on and off not all the time but every now n then and more often than not the fi light comes on when that happens , it does correct itself if I turn it off and on again , I don't think its a big problem but just wondering if it's happened to anyone else, thanks k8 vee
Re: o/d light flashes
« Reply #1 on: August 12, 2016, 18:36:21 »
It happens if the wire connection from the gear position switch develops enough resistance for the voltage output to drop to the point the ECU "thinks" the gearbox is in sixth. With a TRE fitted, it's often the TRE or one of its wires that creates the situation.
Offline plumber02
« Reply #2 on: August 13, 2016, 10:20:33 »
spot on thanks  mac tíre liath , am I going to cause any harm to the ecu , should I get a new TRE  , what about this irregular fi light ???
Offline Pug27
  • Bike: DL1050
« Reply #3 on: August 13, 2016, 10:35:33 »
I had exactly the same problem in May on my K7.
http://www.v-strom.co.uk/smf/index.php?topic=29492.msg293341#msg293341
My OD light would come on on start up when in neutral then the FI light would come on at irregular intervals never when upright though only when it had been running for a while then put on the side stand. Took the TRE off problem solved. Ordered a new one and it's been on since with no problems. My first TRE was just over a year old when it started.
Offline plumber02
« Reply #4 on: August 13, 2016, 11:26:30 »
exactly what's been happening to me I couldn't figure out the deal with laying it on its sidestand but anyway , I've only had the tre fitted 6month I think I only paid £25 ish  so is it the case of what you get is what you pay for or is it just pot luck , do you have a link to where I can buy a new tre please , thanks
Offline Pug27
  • Bike: DL1050
« Reply #5 on: August 13, 2016, 11:33:54 »
I agree I was going round in loops to start with trying to find a link between the side stand and the light.
Anyway the one I bought is this and he offered full 30 day money back guarantee. Nothing to lose.
https://www.ebay.co.uk/itm/400870251565
« Reply #6 on: August 13, 2016, 15:47:12 »
You can always ride the bike in dealer mode to see active codes generated by an FI when an FI occurs. http://www.vstrom.info/Smf/index.php/topic,7061.0.html
You can also get the stored codes read by a dealer with a Suzuki SDS tool or anyone with a HealTech Suzuki OBD tool.
Offline plumber02
« Reply #7 on: August 13, 2016, 16:02:00 »
if it wasn't for that 90 deg lump of an engine and spending near a grand on suspension I'd burn it and buy something with a little less straight from the crate problems
Offline Flanners
« Reply #8 on: August 16, 2016, 20:13:54 »
C'mon they're pretty damn good from scratch for the money, once a TRE fitted almost perfect, well with a few fark alls.
Offline plumber02
« Reply #9 on: August 17, 2016, 16:22:51 »
unlucky or not I don't know 18000miles on the clock ,  swingarm bearings , steering bearings , fork bushes top and bottom  , sprocket hub mod ,clutch basket getting rough- new one needed soon , front springs and rear shock my choice but the stock ones were crap , will I keep it YES would I buy another one YES , I've just spent the last 4 days on a friends BMW 1000 xr my god what a machine BUT I don't know why maybe its just the sound but I'd still if I had both would rather the strom any day
