Petrol leak!!!
Topic: Petrol leak!!! (Read 1083 times)
hesky66
Bike: Fireblade streetfighter,,,,,, DL1050
Petrol leak!!!
August 09, 2016, 16:04:53 »
I've got a petrol leak from the small pipe that connects the throttle body, it's about 2 ins long, after an inspection it looks OK, think it is the one of the two clips that hold it on. Has anybody had this problem??
greywolf
Re: Petrol leak!!!
August 09, 2016, 16:29:48 »
Many people have had the problem. 8mm or 5/16 fuel injection rated hose and hose clamps will fix it right up. Don't use carb rated hose or worm drive clamps. The line has to stand up to 43psi. Use the type on the left, not the right.
hesky66
Re: Petrol leak!!!
August 09, 2016, 21:04:17 »
Cheers for that greywolf will take your advice matey.
Petrol leak!!!
