Diagnostic tools
Topic: Diagnostic tools (Read 1417 times)
BurtonBenson
Bike: CBR
Diagnostic tools
August 05, 2016, 09:52:31 »
Do I need a special diagnostic tool to set the TPS on an 2005 KLV? I see on youtube a bloke setting this on a TL1000 using a tool/switch to flag up idicator bars on the clocks. Is there an easy way to do this without a diagnostic tool?
MartinW
Administrator
Bike: DL650 K4 Blue
Re: Diagnostic tools
August 05, 2016, 12:31:49 »
Why don't you pop over to
INTRODUCTIONS
while you wait for someone cleverer than me to read this
greywolf
August 05, 2016, 14:58:06 »
A paper clip will do for a special tool.
http://www.vstrom.info/Smf/index.php/topic,7061.0.html
Put the bike in dealer mode and a good TPS position will be displayed as a -C00 at idle. The dash on the left is an indicator. It should be in the middle at idle, between 1100-1300rpm, and never go low. Turn the throttle up slowly and the dash should pop to the top position between 1500-1800rpm for a Vee or KLV. It takes about a half second for the dash position to properly reflect the TPS setting so move the throttle slowly or even hold it and wait. It is a very fiddly adjustment. Just tightening the TPS screw can change its position.
BurtonBenson
Bike: CBR
August 30, 2016, 19:04:35 »
thank you I will try
Diagnostic tools
