December 15, 2024, 21:35:44
Author Topic: Had the recall done but ??????  (Read 2407 times)
Offline arran66
  • Bike: DL1000 2015
« on: August 01, 2016, 12:21:43 »
Hi all
Well I had the recall done at the Suzuki dealer
The two plugs under the air box done also the re routing of
Wiring harness and the replacement and re routing of the earth wire on my 2015 V Strom 1000 due to bike cutting out all the time
Guess what riding two up to Gloucester the
Other day and low and behold bike cuts out at low revs exactly the same problem again now it's back too dealer again I'm getting a bit fed up with these problems with this bike it's really a shame because I love the bike but it's really testing my patience now it might even change it its getting close
Has anyone had this issue after the recall your feedback would be greatly appreciated thanks
Offline SimonW
  • Bike: DL1050XT
Re: Had the recall done but ??????
« Reply #1 on: August 01, 2016, 12:58:58 »
Did you get the ECU changed (which wasn't a recall - you have to ask for it specifically)?
Offline bosnjo
  • Bike: DL1000 L7
« Reply #2 on: August 01, 2016, 18:15:08 »
Yes, your symptomps are ECU related. I had the same problem. New ECU (02) now, and haven't done recall yet. Bike is perfect now.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Offline wurzel
« Reply #3 on: August 01, 2016, 19:08:57 »
Ecu as above, that should fix it, and make the bike nicer too. :thumb:
Offline trotts
  • Bike: DL1000 L6
« Reply #4 on: August 01, 2016, 19:31:02 »
Make a coffee, tea, large brandy and read that monster thread here re the ECU. All will be revealed and night will become day ! :)
There were, and still are, some really knowledgeable  folks here.  I bought mine suspecting it would have these issues as you described, the ECU business will resolve all.  Make sure your on the case of the service manager and get him to deal with Suzuki. Do not be 'fobbed' off.  I think its fair to say most dealers seem pretty OK with it.
Offline arran66
  • Bike: DL1000 2015
« Reply #5 on: August 01, 2016, 19:46:04 »
No haven't had the ecu changed bike go's in tomorrow ...I mentioned this too the dealer low and behold again shasam ...they have never heard of it ....they will not do anything without a fight there's obviously a problem with this v strom model.... I had just the wiring changed under tank chaffing ...wiring connecter's that are not waterproof under air box ...and the earth wire changed re positioned .... there now trying to tell me that as I've had the second service carried out by an independent dealer  I've void the warranty on my bike ....which I replied the fault was there long before the second service was even due.... so that really makes there arguement irrellavent as the fault was there before plus they've done a recall for the fault too... they can play the warranty card and I'll play the incorrect fitting and completing of the recall work card
Offline SimonW
  • Bike: DL1050XT
« Reply #6 on: August 01, 2016, 20:38:56 »
Wrong! See: https://www.Suzuki-gb.co.uk/ccr/customer-services-frequently-asked-questions/
Sounds like you need a dealer upgrade!  :thumb:
Offline wurzel
« Reply #7 on: August 01, 2016, 20:59:53 »
It does sound like the dealer is a little reluctant to get their arse in gear and sort out a paying customer, new dealer time maybe..
Offline arran66
  • Bike: DL1000 2015
« Reply #8 on: August 02, 2016, 07:34:26 »
Thanks Simon w
Thanks that's intesting reading yes I'm going too push them on this issue as he said as I haven't had it serviced from them the warranty will be void yes new dealer is on the cards
Offline arran66
  • Bike: DL1000 2015
« Reply #9 on: August 02, 2016, 13:45:05 »
Well bit of an update on my situation Suzuki have now agreed too replace my ecu under the manufacturer warranty so I'm a very happy chappy the dealer did fight it though but common sense has prevailed happy days
Offline wurzel
« Reply #10 on: August 02, 2016, 19:23:19 »
Well that's a result, it does seem there are smell reluctant dealers t there.
