December 15, 2024, 07:34:00
Author Topic: Clock  (Read 2438 times)
Offline vstromjohn
  • Bike: DL1000
Clock
« on: July 29, 2016, 20:20:46 »
I haven't been able to set my clock for years, must be because I have a Power Commander fitted and O2 sensor is disconnected and have the red fault led lit all the time...?
Offline wurzel
Re: Clock
« Reply #1 on: July 29, 2016, 21:28:57 »
Have you fitted o2 sensor eliminator plugs?
They will most likely sort the red light if you have not.
Re: Clock
« Reply #2 on: July 29, 2016, 22:20:06 »
You have answered your own question . With the fault light on you won't be able to reset the clock.
Offline vstromjohn
  • Bike: DL1000
Re: Clock
« Reply #3 on: July 30, 2016, 07:52:33 »
I'll live with it, it's correct 6 months of the year.. :sunny:
Offline vstromjohn
  • Bike: DL1000
Re: Clock
« Reply #4 on: July 30, 2016, 07:58:55 »
I'm sure I did fit the O2 eliminator plug...
Offline wurzel
Re: Clock
« Reply #5 on: July 30, 2016, 10:43:19 »
There should be 2 of them, I think, certainly there are on the 2014 up Veek,  also there is an upgraded eliminator, the old ones have one wire externally crossing over the block, the newer have two, my fi light kept coming on as I had the old version, might be worth a call to dynojet to see if the  two wire one works with your bike, though turning off the motor with the key and restarting extinguished the light for a while.
Might be worth reading the error codes and seeing what's going on.
Re: Clock
« Reply #6 on: July 30, 2016, 11:42:16 »
There is a wire on the ecu plug you can disconnect , I've done it on my Vee. This will turn out your fault light .
Offline hookie
Re: Clock
« Reply #7 on: July 30, 2016, 12:18:06 »
When I fitted a PC on my K8 Vee, there was no plug available from Dynojet or anyone else to disable the O2 sensor and I had to unplug a wire on the ECU plug. Never had any red lights or Fi lights.
Re: Clock
« Reply #8 on: July 30, 2016, 18:49:49 »
There is a thread on removing the O2 sensor here .
http://www.v-strom.co.uk/smf/index.php?topic=4521.msg209511#msg209511
Look at the last post tells you how to turn out the fault light .
Offline bosnjo
  • Bike: DL1000 L7
Re: Clock
« Reply #9 on: July 30, 2016, 23:33:29 »
As for the clock, disconnect the battery and reconnect it exactly at 00:00h. That should sort the time.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Re: Clock
« Reply #10 on: July 30, 2016, 23:46:32 »
Leave it disconnected for a while or it won't reset. On a reset, it starts again at 0100 hours, or 1am.
