December 15, 2024, 11:52:18
Author Topic: Glee front mudguard bolts  (Read 1023 times)
Offline Mark Shelley
  • Bike: GW250 SV650N
« on: July 29, 2016, 13:00:54 »
Fitted a mudguard extenda today so removed mudguard. Why on earth is blue threadlock on the dome head bolts? I didn't want to use heat due to the mudguard being plastic and they were a pig to remove. They bolts are made of that cheese like metal so they have gone straight in the bin and replaced by something better quality and fitted with copper grease rather than threadlock. In 39'yearsbof biking imhave never hadna mudguard come loose.
Re: Glee front mudguard bolts
« Reply #1 on: July 29, 2016, 13:28:41 »
It's so common an issue I made it a sticky warning thread at stromtrooper. Many people have spun the rectangular backing nut trying to remove the bolt and torn up the surrounding plastic.
Offline SuzukiSte
« Reply #2 on: July 29, 2016, 13:38:35 »
Has greywolf said, I did mine a few months ago same problem now just got nylox nuts on there instead such a simple job that took a long time to do. :angry-banghead:
« Reply #3 on: July 29, 2016, 17:38:14 »
I replaced mine at Christmas when I changed tyres and fork oil. Nylon threaded nuts and covered in a big splodge of ACF50 corrosion block on each. Spent more time getting those square nuts off than I did replacing the fork oil  :dl_smiley_banghead:
