Author Topic: Sudden cut out  (Read 1217 times)
Offline roganjoshing
  • Loving my first Vee Twin
  • Bike: DL650 L0
Sudden cut out
« on: July 20, 2016, 14:30:18 »
Stopped behind a stationery  lorry and bike cut out dead. With ignition off the time shows. With ignition on - nothing. Checked battery and fuses. All fine. Also checked side stand switch. Any ideas?
  • Bike: DL650 L0
Re: Sudden cut out
« Reply #1 on: July 20, 2016, 14:31:14 »
Stationary, obviously. Auto correct.
Re: Sudden cut out
« Reply #2 on: July 20, 2016, 17:21:47 »
How did you check the battery? It needs to be under load for a voltage check to be valid. Your symptoms indicate a bad battery, battery cable or cable connection. The connections need to be clean and really tight. I had that happen to me once on a new bike and everything felt okay but the left battery cable did allow a little more tightening. That did the trick and everything was fine after that.
  • Bike: DL650 L0
Re: Sudden cut out
« Reply #3 on: July 20, 2016, 19:02:52 »
Thanks. The AA man came eventually and checked the battery. Had to drop it off at the menders. Hopefully something simple and not expensive.
  • Bike: DL650 L0
Re: Sudden cut out
« Reply #4 on: July 23, 2016, 14:52:22 »
Duff battery, good call. Also found a nail in the rear tyre while replacing the battery so an expensive weekend altogether.
