Author Topic: Flat battery again from heated grips!  (Read 4032 times)
Offline Offtheclockuk
  • Bike: DL1000 K2
« on: July 19, 2016, 21:18:23 »
So Friday I rode from Manchester to donington park for a company track day,  I came out at half 5 when we were done to find my battery completely flat..... I had knocked the heated grips onto the first click (dial type control) or someone had messed with it
Luckily blagged a jumpstart from one of the pit crew and headed home!
The question is.... where is the best place to pick up a switched live so it can't happen again?
 it's happened twice already and I don't fancy getting stuck somewhere stupid
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Flat battery again from heated grips!
« Reply #1 on: July 19, 2016, 21:25:47 »
You could get one of my fuseboxes for 27 quid for a plug and play solution. If you want to diy it, make sure you use a relay, you can pick up a switched live just under the tank, closest to the battery, there's a 2 way connector you can get a feed to trigger the relay. I can't remember the wire colours.
The connector provides the power to the brake light switch.
Offline Hondaman
  • Bike: 650 L3
« Reply #2 on: July 19, 2016, 21:35:53 »
What bike?
The horn is a good switched live on a glee, can't speak for the others.
« Reply #3 on: July 19, 2016, 21:48:53 »
Hi, as your heated grips are wired directly to your battery you are not far from an ignition live . Use the live that goes to your rear brake light switch .
Find the switch and follow the wires, you may find the connector under where you're tank mounts infront of your battery .
Just remove the live wire from the battery (leave the earth connected )and connect it to the live wire of the rear brake switch, no need for a relay .
Offline bigpie
  • Site Donator
  • Bike: DL650
« Reply #4 on: July 19, 2016, 21:50:38 »
I believe the glee has a connector specifically for heated grips that can also be used, but I've no idea where you can find it.
Offline V-Strom3
« Reply #5 on: July 19, 2016, 21:50:55 »
I wired mine to the rear brake switch, so it became ignition switched.
  • Bike: DL1000 K2
« Reply #6 on: July 19, 2016, 22:00:40 »
Yeah sorry I thought I had put my bike in my sig!
It's an '02 1000 or a Vee as it's referred to I think.
  • Bike: DL1000 K2
« Reply #7 on: July 19, 2016, 22:01:43 »
Bigpie do you have a link to your box of tricks so I can have an in depth read?
« Reply #8 on: July 19, 2016, 22:09:17 »
http://www.v-strom.co.uk/smf/index.php?topic=24607.0
Been using mine for all sorts of accessories. So simple even I can do it. Saved me from hacking into the factory wiring.
Offline Hondaman
  • Bike: 650 L3
« Reply #9 on: July 19, 2016, 22:39:10 »
Whichever route you go ALWAYS disconnect the battery earth lead first & reconnect it last.
If you're not up to speed on electrics, a bigpie fusebox would be the best way forward ;)
« Reply #10 on: July 19, 2016, 23:10:16 »
If you get a bigpie fuse holder I can give you a lift with the installation.
  • Bike: DL1000 K2
« Reply #11 on: July 20, 2016, 06:43:37 »
Thanks for the offer o'lofty one!
Offline ziggy
« Reply #12 on: July 20, 2016, 07:03:35 »
Take a supply from the battery through a fuse to a relay, and then onto the grips. The control for the relay supply take from the rear light supply in the tool tray.
Offline Bratton
  • Bike: 2017 MT-09
« Reply #13 on: July 20, 2016, 10:08:16 »
I also use Bigpies fuse box and run my heated grips, usb sockets and soon to be Aux lights from it.
 Only issue I had was the wire that connects to the plug was a little short on mine so couldn't fit it under the seat and had to tywrap it to the frame, which actually works out better for me :)
Offline Tusker
  • Bike: NO BIKE
« Reply #14 on: July 20, 2016, 19:26:22 »
buy these
http://www.fc-moto.de/epages/fcm.sf/?ObjectPath=/Shops/10207048/Products/Oxford-Heated-Grips-Premium-Sports&Currency=GBP&Locale=en_GB&utm_source=Portalexporte&utm_medium=Connexity&utm_term=Oxford%20Heated%20Grips%20Premium%20Sports&utm_campaign=Connexity_GB&Source=CON_GB         note the comment,, they turn themselves off, I have these wired direct to battery and they have been superb. They sense when the alternator isn't running wait a few minutes and switch themselves off
Offline wobblegob
« Reply #15 on: August 03, 2016, 16:01:26 »
Does the 02 not have a switched aux power connector behind radiator cowl ? mine does
Offline BlackRockFox
  • Bike: DL650A XT M0
« Reply #16 on: August 15, 2016, 20:17:53 »
As ziggy said:
Make sure you run through a relay so that there is no power coming from battery until the ignition is on
I took a switched live from under the rear of the seat, the wire that goes to the number plate lights (grey)
Used crimp male/female connectors
Works a treat
Offline 2WheelDrifter
« Reply #17 on: August 15, 2016, 20:41:10 »
I've wired mine through a Denali PowerHub2 along with Sat Nav and have both connected to switched 5-amp fuses.  Took the relay switch off the brown tail light cable (2014 V-strom 1000) and cut out the in-line fuses.  Used Posi-Tite waterproof connectors to arse-end additional cabling (8-amp).  Fiddly putting it all together but works a treat.  Also used cable sheathing from Maplin to protect all cables where they run under/over potential sources of rubbing.  With the PowerHub 2 I still have a another four free connectors for further customising!
Offline Tusker
  • Bike: NO BIKE
« Reply #18 on: August 15, 2016, 21:13:52 »
buy these
Offline sean o caoimh
  • Bike: 2008 650 nonABSvstrom
« Reply #19 on: August 19, 2016, 15:12:07 »
 :dl_soapbox: I used the live for the sidelights to power relay for day running lights. :)
