Author Topic: Clock Resetting Automatically  (Read 2126 times)
Offline krisv
  • Bike: DL650 K5
« on: July 14, 2016, 10:25:21 »
Started up the bike this morning and the clock reset itself from the correct time to 1:00 AM. This is the second time this has happened in 2 weeks. Anyone experienced this before?
Bike is a K5 Wee btw.
Cheers,
Kris
Offline hookie
Re: Clock Resetting Automatically
« Reply #1 on: July 14, 2016, 10:53:26 »
Sounds like the voltage at start up is dropping low enough to re-set the clock. Suggest you check the battery condition and all the battery and ground connections.
Offline Parademic
« Reply #2 on: July 14, 2016, 11:36:14 »
Yep. Had the same issue. It usually resets when you turn the key. If so, it's a sign of the battery being in its way out.
If it's not doing it when starting, it's more likely to be a connection issue, so give your battery contacts a clean and tighten them up.
Gareth
Offline krisv
  • Bike: DL650 K5
« Reply #3 on: July 21, 2016, 09:40:31 »
Thanks fellas.
Update: The whole display went blank for a couple of seconds yesterday when cranking the engine. It also happened again while riding.I had a look at the battery connections and it seems to be tight. I will give it a clean over the weekend and keep an eye out again.
Can this be caused by a loose contact anywhere? If so, where can I locate it?
I am absolutely useless with electrical work.
How do I find out whether it is a duff battery or if its a ground issue?
Any help would be much appreciated.
Kind Regards,
Kris
« Reply #4 on: July 21, 2016, 11:08:06 »
Most likely a dying battery.
Same symptoms everytime my battery had come to the end of it's life.
Have a look on mds batterieswebsite.
Got a yuasa battery for £34.50 delivered a couple of years back.
Offline Parademic
« Reply #5 on: July 28, 2016, 10:51:52 »
Yep. I'll go with mr driver. It's the battery.
Sometimes they are a little confusing too. If u put a multimeter on it, it often shows 12v + but if u try and start the engine whilst it's on u'll see the voltage drop right down to ingle figures.
Treat yourself to a new one.
Gareth
