Author Topic: EBC brake pads  (Read 1642 times)
Offline paulo
EBC brake pads
« on: July 04, 2016, 07:22:03 »
650 AL2 - Hi, Just fitted standard EBC brake pads (rear). Had to push piston all the way back to install them. The replacement pads seem to be wider than the original Suzuki ones due to having more friction material. Should I have fitted the metal back plates and 'paper' like shims, or left them off? -
Re: EBC brake pads
« Reply #1 on: July 04, 2016, 08:08:35 »
The metal shim and pad are meant to be used on the new pads.
They help reduce any brake squeal.
They don't have to be used but I'd keep them around until next time the caliper or rear wheel needs to come off.
Offline revapi
  • Bike: 2019 sv650
Re: EBC brake pads
« Reply #2 on: July 04, 2016, 11:45:33 »
I put ebc pads on mine , I think I remember reading not to put it on , I've had no problems although I still kept them.
Re: EBC brake pads
« Reply #3 on: July 04, 2016, 19:16:48 »
Aftermarket pads should be the same thickness as OEM ones enabling you to put the shims and heat pads on the back of the EBC pads .
The shims and heat pads are desighned to help brake squeak and dispersed heat .
Offline paulo
Re: EBC brake pads
« Reply #4 on: July 05, 2016, 21:40:13 »
Thanks for replies - have now fitted shims etc - all now OK.
