A used but good condition bash plate for the vstrom I used it on my DL1000 2007 check on the Web site
http://shop.enduroguardian.com/Steel-skid-plate-with-bracket-black-STROM-SK-ST-BRKT.htm If you wanted to be fussy you could re powder coat it as there is some flaking around the bottom in places but nothing to bad it looks fine. All bolts are included but you may need longer side stand bolts depending on preference I used mine and they were OK. As the Web site shows its a great heavy duty bit of kit and looks good to. Any questions call 07825005185 pick up is OK looking for £75.00 plus postage as I'm up grading shortly and will not be needed
