No speedo
Topic: No speedo (Read 1033 times)
Graham62
Bike: DL650 K6 Blue
No speedo
June 22, 2016, 23:50:01 »
On my way to Nottingham this morning I looked down at the clocks to see nothing
I was OK for the speed just looked at the Sat Nav but what about the temperature and fuel gauge? turns out its the wire loom behind the front left panel, that's a job for the weekend
Graham
greywolf
Re: No speedo
June 23, 2016, 00:05:14 »
With everything gone, it's likely the black/white earth lead has lost connectivity. Installing headlight relays early would have prevented that but now marginal connections have to be repaired.
Graham62
Bike: DL650 K6 Blue
Re: No speedo
June 23, 2016, 08:45:45 »
Thanks for that GW I've fitted headlight relays soon after buying it, all I had on was the clock (at least I could tell the time). If I move the wires behind the front left hand panel it all comes back on.
Graham
greywolf
Re: No speedo
June 23, 2016, 12:35:08 »
When you get the poor connection sorted, it should last a long time then.
No speedo
