Author Topic: HELP !!!!!!! F1 light just came on  (Read 2537 times)
Offline Holmsey
  • Bike: DL650 L9
« on: June 20, 2016, 05:25:16 »
Travelling into work at half four this morning the F1 light came on and a strange whirring noise appeared ... Suzy was running fine .... got her to work and it appears the fan is stuck on ..... Help !!!!! Any ideas .... This is the first time she has gone wrong on me  :bawl:
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
Offline TLPower
Re: HELP !!!!!!! F1 light just came on
« Reply #1 on: June 20, 2016, 05:46:19 »
Morning mate, http://www.vstrom.info/Smf/index.php/topic,7061.0.html second post by our very own Greywolf will allow you to check the fault code. Fault code should point you in the general direction. It will be a faulty sensor connection or sensor. Brainier people will be along later.
Offline Holmsey
  • Bike: DL650 L9
« Reply #2 on: June 20, 2016, 06:54:52 »
Just flashed the plug over and it showed
C60 Cooling fan relay circuit malfunction
Is that a hard job to fix ?????
I assume it's just the relay gone  :shrug:
IBA Member
« Reply #3 on: June 20, 2016, 12:52:36 »
It could just be just the relay. That's easy to fix by replacing it. It's under the seat between the fuse box and and the right side of the frame on a Glee.
It's shown as pictured on a Veek.
Offline Holmsey
  • Bike: DL650 L9
« Reply #4 on: June 20, 2016, 19:10:55 »
Thanks Peeps .... Kwackboy has had a look and it's definitely the relay .... New one on its way.
Fecking typical though .. fault light was on all the way to the shop .... Kwackboy comes out and the fault has cleared ... I ride away and the light comes on.
Sods Law in action.
IBA Member
« Reply #5 on: June 20, 2016, 19:35:23 »
You fought the law and the law won...
I feel a song coming on!
« Reply #6 on: June 20, 2016, 19:50:08 »
Always the same, customers call the shop with an issue and when they arrive it's gone .  :angry-banghead:
« Reply #7 on: June 20, 2016, 21:12:28 »
Remember Kwackboy, the customer is always right (unless he's Holmsey)
« Reply #8 on: June 20, 2016, 22:26:01 »
Because of this forum Holmsey already had knowledge of the issue already . I just confirmed his suspicions and eased his worry.   :fix:.
