www.v-strom.co.uk/shop
idiots guide to live feed
Topic: idiots guide to live feed (Read 2062 times)
barryw33
Bike: DL1000 K8
June 16, 2016, 20:52:05 »
I have a voltometer to attach to the bike at the weekend (k7 dl000) and want to wire it to a switched live feed. I have only owned the bike for a few weeks so still finding my way around it. I know that the wiring loom goes from the front down the left hand side of the front side panel. Could anyone point out where to link the live wire to, to get a switched feed please? A picture would be amazing
Thanks in advance
kwackboy
Re: idiots guide to live feed
June 16, 2016, 21:36:53 »
Hi ,
I suppose it depends where you want to place your voltmeter. ? That said , a good live feed is the brake light circuit . Obviously don't put it direct to the brake switch wires as you would have extra wires showing so best intercepted the wires earlier in the loom . Another good live feed is the ignition but again you would have to find the block connector for the ignition in order to hide the wires .
Myself I have used the brake switch circuit and intercepted the wires that are in the black block connector behind the radiator.
Fat Rat
Administrator
Bloke/Geezer/Fella
June 16, 2016, 22:01:02 »
It will also depend on the load you want to attach to the circuit and if you are using a Relay.
There is a Heated Grips connector taped to the loom (left side before the loom disappears behind the Rad).
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
barryw33
Bike: DL1000 K8
June 18, 2016, 09:30:03 »
I am fitting a voltometer with two USB connectors, I have a GT so the stock heated grips are already connected to that connector. What colo
u
r wires would I be looking for to get a switched feed to the voltometer?
barryw33
Bike: DL1000 K8
June 18, 2016, 09:36:12 »
This is what I am fitting
http://m.ebay.co.uk/itm/Waterproof-Motorcycle-12V-2USB-Charger-Power-Adapter-Socket-Voltage-Voltmeter-/371564146572?txnId=836321644024
barryw33
Bike: DL1000 K8
Reply #5 on:
June 18, 2016, 16:58:18 »
In the end I feed it straight from the battery as it's got an on off switch at the back
Rusty Nuts
Manufacturer of iron oxide
Reply #6 on:
June 18, 2016, 17:44:20 »
If at all nervous about loom chopping, would a Bigpie fuse box fit the bill? Would give extra switched lives as well.
