In all honesty, I'm not much of a wizz on computers, and the system I'm running is not compatible with power comander.
I don't see this as a problem, as the bike is set up, runs fine, so I don't need to fiddle with the map.
With the Veek, which runs lean from low revs, it is important to get it set up right, for longevity, performance, and to have it run smoothly.
The decat, and in my case airbox mods, have a substantial influence on fueling, and if your modifications are different the map will be of little use on your bike.
Have you not got a dyno centre you can use? We can do the mods, get a pc, but it's the dyno work that makes it all come together, as I'm sure you know.
You don't state what you have done to the bike, or if it is stock, but with a decat, exhaust system valve removal, air box mods...be sure if you load a map, that it is compatible with what you have done, or at best it is pointless, at worse the bike could suffer.
