Author Topic: Power Commander  (Read 1029 times)
Offline Andyonbass
  • Bike: 2014 DL650
Power Commander
« on: June 10, 2016, 16:48:20 »
I see there is a Power Commander that is suitable for a V-Strom on Ebay at the moment if anyone is interested. http://www.ebay.co.uk/itm/142019852226?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
What exactly are the benefits of these gizmos?
Re: Power Commander
« Reply #1 on: June 10, 2016, 17:24:54 »
They are often helpful with lean running Vees. 650s don't benefit from them unless a lot of work is done on intakes and exhausts to get more power and the freer flowing systems get too lean.
Offline Yoyo
Re: Power Commander
« Reply #2 on: June 10, 2016, 18:08:12 »
They enable you to map the amount of fuel going into the engine to remove any lean parts of the rev range, as Greywolf says the Vee runs quite lean, add an aftermarket exhaust and it's very lean, it made a huge difference to my Vee, you can download maps but they are best set up on a rolling road, costs a bit but it's money well spent (if you are having issues)
Re: Power Commander
« Reply #3 on: June 10, 2016, 19:26:56 »
Again though, lean fuel shouldn't be a problem on a 650.
