Author Topic: 2008 DL1000 chudder or something else  (Read 2044 times)
Offline barryw33
  • Bike: DL1000 K8
« on: June 07, 2016, 21:53:01 »
My 2008 DL1000 32k is rough between 3and 4k. I have read about chudder but only in earlier models. Do later ones also suffer from this or is it to do with the throttle ecu etc
Thanks in advance
Offline Yoyo
Re: 2008 DL1000 chudder or something else
« Reply #1 on: June 07, 2016, 22:26:13 »
Chudder is something you feel through a part of the rev range rather than particular gears, it's a fairly heavy shudder or vibration that disappears as the revs build. I'd say it's something else but yes   2008 models could have  chudder.
« Reply #2 on: June 07, 2016, 22:59:04 »
Any 1000 can develop chudder in the 3000-4000rpm range. Here's how to check. http://www.vstrom.info/Smf/index.php/topic,7503.0.html
Offline barryw33
  • Bike: DL1000 K8
« Reply #3 on: June 08, 2016, 19:51:46 »
Yes mine is between 3k and 4k revs(not gears). What's the solution? I have seen a few posts about changing the clutch springs or adding some shims, but it's not for the faint hearted. Is this something I need to get some a mechanic or is there someone, somewhere I can take the bike to who specialises in this and what sort of cost would it be?
Offline wobblegob
« Reply #5 on: June 08, 2016, 20:56:08 »
Just had my 2002 1000 done and would recommend it  :thumb:
Offline barryw33
  • Bike: DL1000 K8
« Reply #6 on: June 08, 2016, 21:37:01 »
What did it cost and where did you get it done
Offline Yoyo
« Reply #7 on: June 08, 2016, 23:16:03 »
My apologies, I read that as 3rd and 4th not 3-4k! All the info is in the link Greywolf shared, I removed my clutch and sent the basket to Sharealike  (John) I had it back on Friday. It cost £350 (I think!) Worth every penny.
