Suspension
Topic: Suspension (Read 1320 times)
Tone
Bike: 2020 V, XT 650. 2022 Triumph speed twin 1200. 1953 BSA A10 plunger.
Suspension
June 07, 2016, 19:55:27 »
Can someone please explain to me what the two adjustments are for on the rear suspension on my glee, dummies guide please.
superteso
Bike: K1300GT my2010, V-Strom 1000 my2014
Re: Suspension
June 07, 2016, 20:22:24 »
can you be more specific?
You mean the knob for preload, and the screw under, for brake adjustment issuance / extension?
si stava meglio quando si stava peggio
greywolf
Re: Suspension
June 07, 2016, 21:14:14 »
One adjusts spring preload to set the sag or ride height. You want the bike with a full load to settle down about 40mm from its position at full extension. That prevents topping out as the bike rises on its suspension as well as bottoming out on big bumps.
The screw under the spring controls rebound damping. Say you ride across a series of bumps. Too little rebound damping will provide a bouncy ride as the spring provides too much return force after each bump. Too much rebound damping will cause the bike to start squatting on its suspension as there is not enough rebound force to extend the suspension until there isn't enough travel left to absorb further bumps.
Preload setting changes are more easily noticed than rebound settings.
wurzel
Bike: DL1000 L4
Re: Suspension
June 08, 2016, 08:51:40 »
GW explains it well, the rebound damping a bit like a self closing door , too much damping and the spring can't close it fully before someone else opens the door again, too little and it slams shut like pinging a knicker elastic.
Suspension
