Author Topic: Brake "click" sound?  (Read 3150 times)
Offline SuzukiSte
« on: June 06, 2016, 18:22:48 »
When I am coming to a stand still low speed at lights ect I get a click sound when I brake the bikes running fine, just gets on my nerve's the click, any ideas folks all I have done is adjust my chain last week.
don't want to start messing with the bike if this is normal.
Offline cip2006is
Re: Brake "click" sound?
« Reply #1 on: June 06, 2016, 19:03:05 »
The pads are playing on the pins, I'm guessing they will need changing soon.
« Reply #2 on: June 06, 2016, 19:42:47 »
Make sure the rear caliper carrier keyway embraces the key welded to the swingarm. If the keyway is above the key, the carrier will loudly click against the swingarm upon braking. A small click can be due to the two main piece construction of the steel rotor disc and alloy rotor hub.
Offline SuzukiSte
« Reply #3 on: June 06, 2016, 20:19:13 »
Bike only done 1500 miles pads are OK.
Sent from my XT1072 using Tapatalk
Offline SuzukiSte
« Reply #4 on: June 06, 2016, 20:25:36 »
Just had a look caliper in key way  but they have stainless steel shims on flicked one and seemed to make noise but less.
Offline JesterRich
  • Bike: Veek 1000 2014
« Reply #5 on: June 06, 2016, 20:33:22 »
Have you checked there is nothing caught in the brake pads, tiny bit of grit ? Try moving backwards and applying brakes.
« Reply #6 on: June 06, 2016, 22:46:07 »
I get a click/clunk from one of the front calipers - have stripped, inspected, cleaned and it still does it. Brakes seem to work fine so I'm not worrying about it.
Offline SimonW
  • Bike: DL1050XT
« Reply #7 on: June 07, 2016, 18:25:04 »
It's not the click of the brake light switch you're hearing is it?
Offline SuzukiSte
« Reply #8 on: June 18, 2016, 16:38:46 »
Don't know but went to the main dealers today for some bolts and stuff and when I give him the Reg number the bike came back with a recall on it was shocked at first then he told me it was for the rear brake light switch so it could be that.
« Reply #9 on: June 18, 2016, 16:45:53 »
The recall on the L2 Glee was for the front brake switch. It would be very unusual for any unit not to have that already done by now.
Offline SuzukiSte
« Reply #10 on: June 18, 2016, 17:01:48 »
My bike has never been registered with Suzuki for warranty I was told only done 1400 miles on a 11 registered bike.
« Reply #11 on: June 18, 2016, 18:53:25 »
See if the front brake switch has a white paint dot on it. That is how the early models at the dealer or after recall service were marked to indicate the recall service was done. Later models had proper switches installed at the factory.
Offline SuzukiSte
Re: Brake click sound?
« Reply #12 on: June 18, 2016, 20:09:39 »
Will do, will take a look in the morning, thanks greywolf.
Offline SuzukiSte
« Reply #13 on: June 21, 2016, 22:06:07 »
To Greywolf you it is the front switch and it as no paint mark on it they have now tried to register the bike in my name.
