Author Topic: Brake Light  (Read 1184 times)
Offline joderest
  • Bike: DL650 K6
Brake Light
« on: June 06, 2016, 13:54:56 »
Hi
Discovered Saturday night, whilst riding home from work that brake light did not work on front brake, rear working fine.
So suspected the switch, took it off, and no continuity between connectors when little rod pushed in, so hope I am correct. Ordered another one Sunday, so waiting for that to arrive.
Question, is this a common fault, the micro switch packing up ?. Its a sealed unit, so could not even get in to repair/clean.
Re: Brake Light
« Reply #1 on: June 06, 2016, 17:22:46 »
Clutch switch is usually the one that goes Pete Tong.
But yeah they can go wrong.
Offline Graham62
  • Bike: DL650 K6 Blue
Re: Brake Light
« Reply #2 on: June 06, 2016, 22:28:28 »
I had the same problem fitted a new one all OK.
Graham
Offline joderest
  • Bike: DL650 K6
Re: Brake Light
« Reply #3 on: June 07, 2016, 10:29:06 »
Thanks, just in case there was something else I should look at.
Have already done clutch one.
Searching e bay, there was loads of front brake light switches, ranging in price from £1.99 to about £10 !!!!!, so bought a middle priced one, as its only a micro switch, thought that would be safe.
Oh for the days when you could clean the contacts and have a working item again.
