Hi All,
As some of you may have seen from a previous post I am experiencing an intermittent loss of headlights on startup, most likely due to the starter switch. I just have a couple of questions about the relay kits..
I'm assuming the kit completely bypasses the starter switch and takes switch live from the headlight circuits? Does this mean the lights stay on as the bike is started, probably not an issue unless it's cold/weak battery etc?
Is there somewhere I can get a wiring diagram of the kits as I might have a go at putting one together?
I am looking into sorting the other electrical bits on the bike as other accessories have been wired straight to the battery, does anyone have a recommendation for a an aux fuse panel that I can wire to a relay?
Cheers!
