Author Topic: Clutch slave cylinder removal  (Read 1450 times)
Offline Brewers Whoop
  • Bike: 2014 DL1000A
« on: June 01, 2016, 07:59:30 »
Yesterday I was on hands and knees peering into nooks and crannies of my V2 (as you do). There was a fair amount of crud visible under the chaincase in the vicinity of the front sprocket. I've read the threads about this not being over-super for the clutch pushrod.
To clean this out, I presume the clutch slave cylinder has to be moved out of the way before the chaincase can be unbolted? If so, can I just undo the fasteners and move it aside to gain access and then replace it when done. Or is it a bleeding job, in all senses?
Thanks
I'm sorry Dave, I'm afraid I can't do that
Offline Yoyo
Re: Clutch slave cylinder removal
« Reply #1 on: June 01, 2016, 08:39:59 »
I did mine before selling my 06 plate Vee, you can just remove it but you need to put a cable tie or similar around it while you work or the piston will ease itself out. It's a job worth doing, it gets pretty messy in there!
