Author Topic: secondary butterfly removal  (Read 1208 times)
Offline mickyc
  • Bike: 04 wee 97tl1000s
« on: May 31, 2016, 11:10:21 »
Hi just had a dig around under the tank of my 04 wee
found secondary butterfly flaps had been removed also PAIR feed from airbox blanked off  bike runs fine no problems, bike came like this so can't compare it with standard set up .Did similar mods(and much more) on previous TL1000s & SV1000s. Do they have any affect ,positive or negative on the wee ? :old: :shrug:
Re: secondary butterfly removal
« Reply #1 on: May 31, 2016, 11:33:33 »
I removed the butterflies as I had issues with the STVA but once sorted the bike ran great.
Slightly sharper throttle response as the computer was less involved.
MPG was unaffected.
I know a few have removed the pair system as it gets in the way when working on the bike and not needed in the UK as bikes aren't emissions tested. Suppose it saves a bit of weight too.
« Reply #2 on: May 31, 2016, 13:47:34 »
Don't remove the butterflies on a Wee. It doesn't have any restrictions to unrestrict.
