New tyre- "Be careful"
Topic: New tyre- "Be careful" (Read 1697 times)
lekyuk
Bike: DL650 L2
May 30, 2016, 20:16:56 »
Hi,
I've just had the front tyre changed and I got the "be careful on it" advice from the garage. So what is the official rule on new tyres and "being careful"? You buy lots of products that you don't do 70mph (or more) on and get endless bumf about safety but a tyre, you get a very unspecific "be careful". Anyone?
Leky
2012 AL2 650 V Strom
MartinW
Administrator
Bike: DL650 K4 Blue
Re: New tyre- "Be careful"
May 30, 2016, 20:23:19 »
Just don't give it "full welly" for about 100 miles.
Some people follow the rules and some don't.
The tyres may have a release agent on the tread to get them out of the molds. I don't think it is as important a rule as it used to be.
lekyuk
Bike: DL650 L2
May 30, 2016, 20:27:25 »
Thanks. I went up the Cat and Fiddle yesterday and coming down had some controlled fun, that is probably after doing 60 or so miles on it, felt fine. Just seems strange that a tyre would be sold with a residue on it which compromises grip. At least fitter could have a solution which removes the residue. Never understood it...
Leky
frez
May 30, 2016, 21:22:21 »
I generally forget all about taking it easy after 5 minutes unless it's raining.
Yoyo
May 30, 2016, 21:46:25 »
I'm with Frez, they recommend 100 miles but normally within a couple of miles that 'shine' had gone off the tyre and they are fine, the issues occur when it's raining or when you crank it right over quickly early in a ride.
Joe Rocket
Bike: DL650A L5, Kawasaki GPX750R
Reply #5 on:
May 30, 2016, 21:53:04 »
I think it's just 'covering arses speak'.
"Well, we did tell you........"
wurzel
Bike: DL1000 L4
Reply #6 on:
May 30, 2016, 22:21:32 »
I just go for a short first ride maybe 20 miles tops, and increse lean angle progressively through the ride, same with the brakes, also traction control off the Veek, first gear, weight forwards and give it the beans ....ahem
Captain
Bike: DL650A K9 GT. DL1000A L6
Reply #7 on:
May 30, 2016, 23:05:26 »
According to the tyre manufacturer michelin. They ditched the release agents a while ago. They use some on the tyre walls around the lettering but none on the tread part. I think it's just a case of scrubbing the tyre a bit to get rid of the smoothness. But I think mentally you need to do 100 mile I know I do.
wurzel
Bike: DL1000 L4
Reply #8 on:
May 31, 2016, 03:23:41 »
That is interesting Captain, and must admit, having just had a new rear pilot 4 on the back, within 5 miles on dry roads had it to the edge in corners, expecting it to move about a bit but it was planted.
