Author Topic: Bar Risers  (Read 3213 times)
Offline NTBooth
  • Bike: Benelli Trk502x
Bar Risers
« on: May 23, 2016, 22:49:13 »
Looking for a pair of risers - approx 20-30mm rise, just straight up not up and back.
Silver or black, colour not important.
Thanks
NTB
Re: Bar Risers
« Reply #1 on: May 24, 2016, 20:19:21 »
M&P have them for £10.
26mm - fitted them to my old Wee.
Offline NTBooth
Re: Bar Risers
« Reply #2 on: May 24, 2016, 21:58:41 »
Thanks Mr Diver!
ill have a look now.
if your able to pop a link on that would be wonderful!
26mm, did you need to change cables or anything like that?
Thanks
NTB
Re: Bar Risers
« Reply #3 on: May 24, 2016, 22:05:17 »
Cables will be fine. You may need to persuade a bit more of the loom out from under the tank and up by the headstock, but nothing major.
Offline NTBooth
Re: Bar Risers
« Reply #4 on: May 24, 2016, 22:06:10 »
Think I found them
http://www.mandp.co.uk/index.php/default/universal-handle-bar-raiser-riser-kit.html
With the bottom of the risers being flat do they not sit funny in the original fittings because they're not round?
Nothing more than a 5 minute job to fit I presume? as for persuading the loom I presume there is enough play in the lines to do this comfortably?
Re: Bar Risers
« Reply #5 on: May 24, 2016, 22:08:44 »
I put 26mm on mine with no problems.
I did have to slide the brake line slightly further up the clamp on the underside of the headstock but that was just loosen, slide and retighten.
Offline NTBooth
Re: Bar Risers
« Reply #6 on: May 24, 2016, 22:11:10 »
Thanks Martin, I remember us having a brief discussion about this a few months back where you sent me some pictures. looked very simple, just rotating a bracket 90 degrees, Good to know!
Infact...were those risers not the ones that Mr Diver is referring to? I think they came off his old strom and you pipped me to the post buying them!?  haha
Re: Bar Risers
« Reply #7 on: May 24, 2016, 22:13:22 »
No, they weren't Diver's - I got mine from Jeff999
Offline NTBooth
Re: Bar Risers
« Reply #8 on: May 24, 2016, 22:24:04 »
ahhh, righto!
well, as I said previously:
Is this an issue at all or just something I'm thinking of to stop my self parting with a tenner? (yes I really am that tight sometimes :whistle:)
Re: Bar Risers
« Reply #9 on: May 24, 2016, 22:39:12 »
Mine went with the bike to the breakers.
I couldn't be arsed to remove them when they only cost £10
But the ones you found are the exact ones I bought. The flat bit actually created a small void.
I had Goodridge braided hoses that were a little on the short side compared to the stock lines but still fitted OK.
Offline NTBooth
Re: Bar Risers
« Reply #10 on: May 25, 2016, 10:36:45 »
Thanks everyone for your replies!
you've all been a big help. Decided to order some as I really think I need them. I have a long history of back issues and the very slightly forward stance I am riding in because I am fairly tall and the height of the bars I think is making it uncomfortable on longer rides.
will see how I go on with them when they arrive.
