Hi all,
I don't know what they are called, but does anyone know where I can get hold of the rubber fittings, the ones that hold the screen on that has a nut glued on the end to take the bolt, and then push fits in the holes, about 10/15mm ( I didn't measure whilst off ) then you bolt through into this rubber fitting? Sorry didn't explain it very well, but hopefully someone will know what I'm wittering on about, cheers.
