Author Topic: Changing gearing.  (Read 1620 times)
Changing gearing.
« on: May 20, 2016, 20:22:31 »
Before we start this is for the Varadero, but relates to the Strom.
Like the Vee, Veek and Glee the Varadero's speedo pickup runs from the engine output shaft not the front wheel like it does and my old wee.
I want to change the gearing to make it a little less sluggish as it feels like you're starting off in second when you are in fact in first.
If I swap the rear sprocket for one with a few more teeth how would this affect the indicated speed.
The indicated speed reads 8% over atm.
Will it get closer to the actual speed or get further away from actual.
I'm usually good with things like this but this ones got me stumped.
Online Rusty Nuts
Re: Changing gearing.
« Reply #1 on: May 20, 2016, 20:27:46 »
Larger rear sprocket, slower road speed  for same gearbox output speed, you'll be going even slower than the speedo thinks.
« Reply #2 on: May 20, 2016, 20:33:16 »
Bollocks
And there is no speedo healer for the Varadero.
#edit. There is a speedo healer... I just can't spell on ebay.
« Reply #3 on: May 20, 2016, 20:54:27 »
Hi ,
When ever I've adjusted gearing on bikes the speedo has always read faster than you are actually going when you lower the ratio .
