do you still fit shims behind pads want a strom owners experience
Topic: do you still fit shims behind pads want a strom owners experience (Read 3171 times)
Jameswigan
Bike: VStrom 650 GT 09
May 17, 2016, 18:16:14 »
quick question just taken my pads out (the original pads that came with the bike) and they have a wrap around shim and a other shim as shown in the picture.searching google says they are not needed these days but I would rather check with you blokes 1st.thanks all
mr_diver
Re: do you still fit shims behind pads want a strom owners experience
May 17, 2016, 19:09:41 »
Yes. Use the shims.
Jameswigan
May 17, 2016, 19:20:16 »
Will do,there is so much conflicting information about this area I never know what to follow, also the old pads have plenty life in them with even wear not sure if they are of use to anyone near me?? Only changed because I wanted double h pads.
Holmsey
Bike: DL650 L9
May 17, 2016, 22:40:26 »
Left mine on .... No issues.
Life on two wheels is better than 4 because the wife don't go on two wheels " I'M FREEEEEEEEEEEEEEEE "
IBA Member
RBLR 1000 - 2018 -2019
Armistice 1000 - 2018
obalanga
Bike: DL650 K8
May 17, 2016, 22:50:44 »
bugger!! just did my brakes today and of course, I left them out.
greywolf
Reply #5 on:
May 17, 2016, 23:24:29 »
It's not a big deal.
joderest
Our other Strom, Daughters pony
Bike: DL650 K6
Reply #6 on:
May 18, 2016, 07:53:26 »
My rear brake has the shims, my front brake does not, I use a smear of copper ease grease on the rear of pads, and have no issues.
As GW states, no deal really
Rich:-)
Reply #7 on:
May 18, 2016, 09:44:17 »
What do they do anyway?
I have had some brake pads that come with shims & an insulation plate, the thinking is that some pads want to hold in the heat to get the pad material hot, others have no insulation as they want the heat to conduct through to the caliper.
So what's the job of this stainless steel shim when not used as part of an insulator?
Jameswigan
Reply #8 on:
May 18, 2016, 10:48:29 »
I fitted them anyway with a little grease on back of shim for good measure.went out tested the rear and it's much better than before either the original pads I opted for semi sintered v pads on a whim,got to do the front tonight so will carry on with the shims
Stromtrooper james
Bike: DL650 2011 70K+miles DL1000 2017 12k miles
Reply #9 on:
May 20, 2016, 11:39:26 »
I Took mine of and binned them. about 25,000 miles ago
Black Mamba Biker
https://www.youtube.com/c/blackmambabiker
kwackboy
Reply #10 on:
May 20, 2016, 21:25:38 »
Quote from: Rich:-) on May 18, 2016, 09:44:17
Some bikes have them and some don't but if your bike has them I'd suggest keeping them . They can help dissipate the heat which can cause brake fade and help stop squeals in your brakes.
To buy they can be expensive for what they are so keep them.
