Author Topic: commuter sprockets on DL1000  (Read 923 times)
Offline barryw33
  • Bike: DL1000 K8
« on: May 15, 2016, 00:47:05 »
Bought my DL1000 for commuting, but find it a bit juddery at low revs in traffic. Is there a standard sprocket charge that can give a smoother ride at 3-4k revs without going into the clutch basket shenanigans?
Offline StromGeeza
  • Global Moderator
  • Bike: just scoots now
Re: commuter sprockets on DL1000
« Reply #1 on: May 15, 2016, 08:16:41 »
Timing retard eliminator?
It's plug and play and easily removed to go back to stock.
« Reply #2 on: May 15, 2016, 12:52:33 »
Check for clutch chudder. http://www.vstrom.info/Smf/index.php/topic,7503.0.html
If chudder is the cause of the problem, you need to get out of the rev range that causes the problem or see Sharealike for a clutch fix.
A sprocket change will change the rev range you are in at a specific speed. It will not affect the feel at 3-4k rpm but the speed. The idea would be to lower the gearing so you get over 4k rpm or simply downshift.
Typically, the cause of 3-4k rpm running issues is the fueling is too lean. Getting above that range or changing the air/fuel ratio at that rev range will work better than a TRE which has its biggest effect at very high rpm. A TRE may be enough though and is much cheaper that a Power Commander. Changing the low range to a richer mixture can also be done with a Yoshi or Teka box that rewrites the stock ECU settings if you can find somebody with one.
