Author Topic: Centre Stand  (Read 1134 times)
Offline Ernie
Centre Stand
« on: May 14, 2016, 21:01:47 »
2010 Lo DL650 Centre Stand
The Above on my bike is very stiff,I have sprayed all the working parts and springs , But when I take the bike off the centre stand I nearly have to use my hands to get it in the folded position , Any thoughts on this problem Thanks in Advance
Re: Centre Stand
« Reply #1 on: May 14, 2016, 21:11:49 »
I've seen this too. Just clean the pivot points with something like paraffin and a tooth brush. It should then start to pop back up properly.
Re: Centre Stand
« Reply #2 on: May 14, 2016, 21:37:15 »
+1 mine was covered in crud but cleaned today and pops straight back up (I haven't re-lubricated the pivot points yet but it's the smoothest it's been in months)
Re: Centre Stand
« Reply #3 on: May 14, 2016, 21:53:13 »
I put a grease fitting on each side in front and cut a spiral groove around the pivot pin as a grease channel after getting tired of disassembly to clean and lube. I never had to take it apart again.
Offline Ernie
Re: Centre Stand
« Reply #4 on: May 17, 2016, 19:13:48 »
Thanks for the replies
