Author Topic: Which Electrical Connection ?  (Read 969 times)
Offline Dave
« on: March 22, 2016, 13:27:36 »
In one of the threads below, there is mention of an electrical connection that appears to corrode in normal use, (they say in front of airbox and behind radiator ) anyone know what the connection is for ?. I have my bike booked in for the top end recall, and was going to ask them to clean and proof this connection at the same time if it's a known problem, thanks Dave
Re: Which Electrical Connection ?
« Reply #1 on: March 22, 2016, 13:42:47 »
There are a number of connectors pinned behind the radiator top shroud on all models. You didn't mention your model but top end recall would indicate a Glee. Anyway, all should be treated. The connectors from both handlebar switch pods, the fan switch, the power point or heated grip accessories and the ignition switch are all there.
« Reply #2 on: March 22, 2016, 21:07:12 »
Ideally you need them to do this too:
(Cover all connectors in tubing)
