Running without Suzuki op box
Topic: Running without Suzuki op box (Read 1579 times)
mrp192
Bike: V-Strom 1050
March 18, 2016, 15:33:32 »
Hi, my Glee came equipped with Suzuki plastic panniers and topbox. I have removed the pannier mountings but the mount for the topbox appears to be a semi permanent plate screwed to the standard rack.
This mount has four rubber bungs pressed into it for the topbox to sit on but these bungs are otherwise quite loose but won't pull straight out.
Is it OK just to pull these upwards to remove them for safe keeping whilst riding without the luggage? I can't see what's keeping them in but don't want to break them or lose them if I leave them in.
Thanks.
S2Rgar
Bike: DL1000 L9 Black - DL650 AL5 Red (SOLD) - DL650 AL3 Grey (SOLD) Suzuki GSX-S1000
Re: Running without Suzuki op box
March 18, 2016, 15:44:35 »
Is it these things ? -
http://www.ebay.co.uk/itm/Givi-Kappa-Z126-Rubber-Bungs-x4-for-Monolock-Monokey-Base-Plates-Wingracks-/300885089289
If so they just pull out. Mine sit quite loose too.
mrp192
Bike: V-Strom 1050
March 18, 2016, 17:29:04 »
Look very similar, I'll have a go at working them out then and store them in the top box until I go on my travels. Thanks.
Mr Nick
Certified Fisher Price trained technician
Bike: 1979 Suzuki TS185ER, 1979 Moto Guzzi V50, 1989 Moto Guzzi SP3, 2010 KTM 990 Adv
March 18, 2016, 20:15:04 »
I'm curious why you feel the desire to remove them: I ran around quite happily with the Givi plate complete with bungs on my Glee & do the same on Katie.
Orange Bikes Matter!
mrp192
Bike: V-Strom 1050
March 18, 2016, 20:23:46 »
Hi Mr Nick, if they stay put when riding without the box I'm happy to do that'll. It's because they spin quite easily I assumed they may come out and get lost if not removed.
UK_Vstrom650
Bike: DL650A L2
Reply #5 on:
March 18, 2016, 22:04:35 »
I wouldn't think about removing them as pulling out over and over will probably make them easier to come out, and they're cheap enough to replace if you ever need to... but if you want to, pull them out with some pliers
