Author Topic: For those that have (or had) gear indicators  (Read 1209 times)
ProfG
« on: March 18, 2016, 15:00:49 »
Where did you attach the sensors? (or where is it attached if you bought your bike with them already on?)
Re: For those that have (or had) gear indicators
« Reply #1 on: March 18, 2016, 17:06:05 »
I bought the more expensive GIpro DS gear indicator. It is Suzuki specific and plugs into the dealer mode connector, using the bike's built in gear position sensor that feeds the selected gear number to the ECU. http://www.vstrom.info/Smf/index.php/topic,7061.0.html
ProfG
« Reply #2 on: March 18, 2016, 17:27:54 »
Being a cheapskate, I bough the cheaper one. I have no problem connecting it up, just wanted to see where others have their sensors, not the wiring. Maybe someone has a better idea and did a better job than me that I could copy or learn from.
There are a couple of positions but they are prone to dirt, grease and gunge.
My previous bike had a gear indicator but I never looked to see where the sensors were attached. I may try and track it down and check for myself.
Offline Big Rab
  • Bike: V-STROM 650
« Reply #3 on: March 19, 2016, 08:35:01 »
I bought one off, bigpie on here. fits straight into the plugs under the tank. and fits neatly inside the rev counter.
