Author Topic: Pillion comfort  (Read 5129 times)
Offline Kayaker413
  • Bike: 2008 650
Pillion comfort
« on: March 16, 2016, 10:33:27 »
Hi Folks,
I was wondering if anyone has any top tip for getting my pillion a bit more comfortable.
The wife has a bit of a bad back so won't come out for more than 1hr30 or so.
She has pants that fit and aren't putting pressure on anywhere, which has helped.
Put the top box on so she doesn't worry about going off the back.
We have intercom so she can chat.
Any other top tips. I wondered if the pillion pegs can be lowered to reduce the knee and hip angle.
Anyone got any top tips or just get her used to coming out?
2008 650
Offline krisv
  • Bike: DL650 K5
Re: Pillion comfort
« Reply #1 on: March 16, 2016, 13:58:17 »
Cheap Solution: Leave the missus at home and go solo.
Expensive Solution: Honda Armchair (Goldwing)
It is important where it starts becoming uncomfortable, knees or lower back or upper back. I don't think much can be done for lower back, apart from posture or wearing a back support belt or maybe softening the seat to reduce impact on the spine.
Re: Pillion comfort
« Reply #2 on: March 16, 2016, 14:57:21 »
Some move the top box backwards, some have back rest pads on the top box,  yes you can find adjustable pegs.
Offline alan29
  • 200th Member
  • Bike: DL650XT M0
Re: Pillion comfort
« Reply #3 on: March 16, 2016, 15:12:55 »
My wife has bad knees. Hasn't stopped her though. Our answer is to stop every hour and have a 5-10 minute stretch. Have done two fortnight trips to France using that system.
Re: Pillion comfort
« Reply #4 on: March 16, 2016, 17:42:41 »
My wife has painful knees and hips, not made any better by riding pillion. Painkillers are always in the top box.
She doesn't like the back rest on the top box, it pushes her too far forward (even with the box set further back) the back protector in her jacket is enough to cushion her.
Don't accelerate or more important brake too hard, then they don't have to use their legs to stop themselves sliding forward.
Having the intercom is a bonus, she will tell me she is going to drop her legs off the pegs for a stretch or asks me to slow down for a bit so she can stand on the pegs for a bit of adjustment. (These done in sensible/safe/ quiet areas).
11/2 hours seems to be our cut off time. 10 or 15 minutes is usually enough to refresh.
When touring we stop regularly, often before the 11/2 hours to have a break/look around/coffee, etc trying not to get to the point where you 'need' to stop. Once you get to that point that 'need' time gets shorter as you go on!
It's not as much fun on the pillion so listen to their requests opinions etc. They will differ to yours! (In fact that's usual isn't it?)
Most important, never frighten them!!! Cornering too fast or 'close' overtakes etc causes sharp pains in the riders kidneys!!!  :violence-smack:
Offline Kayaker413
  • Bike: 2008 650
Re: Pillion comfort
« Reply #5 on: March 17, 2016, 09:08:48 »
 lol
Thanks blokes, may look at lowering the pegs. She is 5"11 so I think that would help and take pressure off her lower back a touch.
Her back problems come from to much time at a surgical table causing tight hamstrings.
2008 650
Offline sirkitchalott
Re: Pillion comfort
« Reply #6 on: March 17, 2016, 23:21:56 »
I moved the top box back... She loves it now!
KE125, RXS100, X7 250, GPX 750R F2, ,GSX400F, Z750, VN900, PAN1300, DL1000
Re: Pillion comfort
« Reply #7 on: March 17, 2016, 23:25:26 »
Yep move the topbox plate back and it'll make quite a difference.
Chippy4467
Re: Pillion comfort
« Reply #8 on: March 19, 2016, 16:17:08 »
"Mr Chippy" finds the back of the Vstrom uncomfortable - slightly expensive solution but she's very happy on the back of my TEX - 4000 mls in 16 days was no problem :thumb:
Chippy
Chippy4467
Re: Pillion comfort
« Reply #9 on: March 19, 2016, 16:18:19 »
slight typo - I meant Mrs Chippy - doh
Offline Hacknslash
  • Bike: Vstrom
Re: Pillion comfort
« Reply #10 on: March 19, 2016, 22:10:20 »
Hola
I recommend riding for an hour and having a short break, 5 or 10 mins is fine. Your wife is likely to travel larger distances like this.
Ian
Offline Firestorm
Re: Pillion comfort
« Reply #11 on: March 21, 2016, 10:16:38 »
I moved the topbox back and fitted some MFW Vario footpegs which lower and move forward the pillion pegs. Not cheap but worth it and you can keep them for your next bike as you only need to change the actual mount for different bikes.
Offline Mark Shelley
  • Bike: GW250 SV650N
Re: Pillion comfort
« Reply #12 on: July 14, 2016, 11:28:37 »
I have had to move every Givi top box plate back on every bike I have had one on if I wanted to take a pillion comfortably.....and that has been loads.
Offline Coast
  • Bike: 22 Strom 650
Re: Pillion comfort
« Reply #13 on: July 18, 2016, 21:10:38 »
Anyone got any photo's of their modified base-plate for the top box, just to get some idea of how far it is possible to move it further back....
