Had a few packages delivered to work yesterday.
A small clear screen for the Xj600n
A PAIR removal kit
HealTech Speedo Healer.
The PAIR system injects clean air from the airbox to aid combustion of unburnt fuel in the exhaust but also dilutes the nasties in the exhaust gases, basically a cheat for the emmisions.
With the free flowing exhausts and K&N air filter the bikes pops and bangs like buggery on throttle roll off. Now that is much reduced.
After I swapped to the 15t frobt sprocket my speedo has been reading high... 80mph indicated 69mph with GPS. And the odometer was also reading high about 11%.
Easy piece of kit to fit and calibrate and now my speedo is super accurate- I may change the setting to allow some leeway.
Then went for a sunny ride to Porthcawl, very busy there. Being an antisocial miserable git, I did a loop and went back home
