Oil and filter change on the Vardero.
Cleaned and re-oiled the K&N air filter.
Made a rookie mistake when taking the sump plug out.
On the Varadero the sump plug is on the left side of the sump not underneath, making it far easier to acsess.
BUT, you need to move the bowl quite far out from under the bike to catch the initial flow.
I cought most of the oil.
Unfortunately quite a bit of that initial flow poured straight into my 30 minute old 120 piece Halfords professional tool set.
It least there is no chance of any of it rusting now.
![dl_smiley_banghead :dl_smiley_banghead:](https://www.v-strom.co.uk/smf/Smileys/default/dl_smiley_banghead.gif)
While I was there I removed a years worth of grunge from behind the front sprocket cover and greased the clutch rod actuator.
All she needs is a new set of Tourance (original) to be fitted on Thursday and some nice weather to ride it.
![sunny :sunny:](https://www.v-strom.co.uk/smf/Smileys/default/sunny.gif)
