I hadn't intended doing anything other than fixing up what was already there and moving it on: I had the use on an SV for a day and didn't get on with it so I'm unlikely to want to keep it.
A basic top yoke for the conversion is £125, probably an easy £200 for the whole setup, which I'd never see back in a sale price premium for doing the job.
Tonight was a bit frustrating: I polished up and re-fitted the 2 sides of the rear bodywork, then remembered that the centre section has to be fitted to them first, so off they came and then back on with that bit attached.
![banghead :angry-banghead:](https://www.v-strom.co.uk/smf/Smileys/default/banghead.gif)
Then I fitted the airbox and had that all sorted. And spotted that I needed to have put the upper fairing mounts on first so it had to come back off too..
Well, I can always get things ready for filling the brakes, but you can't get into the rear brake reservoir with the bodywork fitted, so took it all off yet again.
![dl_smiley_banghead :dl_smiley_banghead:](https://www.v-strom.co.uk/smf/Smileys/default/dl_smiley_banghead.gif)
However, I did fit the sidestand and the left hand switchgear & cables. None of which have had to come back off (yet)...
