decided to fit the new accessory relay kit I picked up a few weeks back.
https://www.ebay.co.uk/itm/374591898395The clips on the connectors I'd bought previously would break connection with the vibration of the bike, so go over a bump and the heated grips and aux lights would cut out
New set up is a bit neater the old one, everything runs through the relay box, thought the selection of fuses it came with were rather limited, So I'll need to pick up a couple of 2 & 3 amp micro fuses as spares.
I've still got the dash socket & USB port and heated gear socket running direct to the battery as the load is a bit more that I want going through the relay, plus I want the power with ignition off.
Took it our for a spin on some bumpy roads while the sun was shines - 40 miles of sun and dry roads - didn't see that happening given the weather we've had recently.
Back home, after a quick fuel fill and rinsed off and put back to bed - I'm hoping to use the bike for a bit of commuting in January as long as the salt holds off.
