Put the battery back in the Varadero, connected the battery lead for the Gerbing heated jacket I bought last weekend and took it out for a spin.
100 or so miles around the some of the B roads and single tracks between Port Talbot and Llandovery.
Came back down the upper Swansea valley and back over the top to Glyn Neath.
Heated jacket worked well, couldn't stick it at 75% for more than a few mins, 50% seemed about right.
My heated grips died just after going through Llandovery had to switch to the winter insulated gloves.
![icon_argue ###](https://www.v-strom.co.uk/smf/Smileys/default/icon_argue.gif)
I was wondering if it was an issue with low voltage cut out, or maybe the heated jacket drawing too much power but it would seem from testing this theory later that the old Hotgrips I have don't have the auto cut out of the newer ones.
Got home and discovered the wiring loom I made for a ignition switched relay had corroded badly and was making intermittent contact for the heated grips circuit. - it's gets covered in road crud, but there is precious little space under the seat and it has lasted 6 years!
![smiley_shrug :shrug:](https://www.v-strom.co.uk/smf/Smileys/default/smiley_shrug.gif)
Spent the next hour assembling a new relay loom from the bits in my tool box.
Heated grips and bikeviz bullet lights back working!
![bothhands-meholdit-spanner :fix:](https://www.v-strom.co.uk/smf/Smileys/default/bothhands-meholdit-spanner.gif)
Bike is now filthy and likely to get worse this week commuting to work if the roads don't get salted.
![Dirt Bike :auto-dirtbike:](https://www.v-strom.co.uk/smf/Smileys/default/dirtbike.gif)
But at least my hands will be warm again!
