A) yes you are correct
B) yes, I believe they should be similar.
I presume the vacuum connection is on the inlet ?, as this could be leaking /split.
To detect a leak, let it run on idle then spray WD40 or similar around the carbs / inlets.
The idle should raise if there's a leak .
