I found a Colortune when I was tidying out the garage: can't remember if I kept it or tossed it as I'd not used it in probably 30 years. Next time I'm out there, I'll take a look & if it's still there then you can have it.
I was out tonight applying threadlock to the disc bolts when I spotted something that I hadn't been aware of:
I've been fairly diligent in doing the axle nut up to the right torque, but that looks to me like it's been overtightened at some point (maybe not me - I've only had the nut off half a dozen times or so). Luckily it's not too scary - £52 at Eurotek got me an axle with that block, the other side block, and nut, so not Suzuki prices (wrong side of £130 for axle & nut on a Glee...).
The nut being alloy, I'm a little surprised that it's cracked the block before stripping the threads: the nut is only £7 and would have been preferable, but you don't always get to choose. A minor thing I've noticed is that the axle seems to be in the wrong way around compared to others I've seen: don't think that would have made a difference & caused this, but it'll go back in the other way round just in case.
On a plus side, I also measured the front discs and they're both at 4.95mm so plenty meat left on those (5mm new, 4.5mm min).
