I have mine in the dash surround - it's a bit daunting drilling a 30mm odd hole in a pristine panel....., fused & attached directly to the battery, that way you can power stuff without the ignition on (I also use the ciggy socket for the bike charger.
There is no current draw with the socket so it won't discharge the battery
Phil
