Author Topic: Reg/Rec Recall  (Read 2869 times)
Offline ziggy
Reg/Rec Recall
« on: January 28, 2016, 17:56:31 »
I wonder if this recall in America is the one already carried out here?
http://www.wcpo.com/news/national/Suzuki-recalls-more-than-68k-motorcycles-over-stalling-risk
Offline user650
Re: Reg/Rec Recall
« Reply #1 on: January 28, 2016, 18:11:02 »
This recall is the one done about 6 years ago, I remember taking my 1250 bandit in to get it sorted (new reg fitted)
From VOSA Site
    Regulator/Rectifier unit may fail in use due to poor adhesion between an internal circuit board and the external heat sink (external casing). resulting in an open circuit and failure. This causes insufficient battery charging current to the battery and can lead to engine stalling and non start when in use.
If It Starts Ride It
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Re: Reg/Rec Recall
« Reply #2 on: January 28, 2016, 18:14:06 »
The link might not work as is. Load it and if it doesn't then change the capital S in Suzuki to a lower case s to get the link to work.
 :thumb:
It's a downside of the filter changing the word Suzuki.
Re: Reg/Rec Recall
« Reply #3 on: January 28, 2016, 20:37:28 »
It's different. The earlier regulator/rectifier issue in which the circuit board may separate from the heat sink did not affect years beyond 2009. The USA had that recall too.
Offline user650
Re: Reg/Rec Recall
« Reply #4 on: January 28, 2016, 21:21:29 »
Sorry my mistake, the dates on the recall cover from around then upto 2012
Dealers will replace the charging system regulator-rectifier to fix the problem. Suzuki will notify owners and begin the recall repairs in early March at no cost to owners.
The recall covers the 2008 to 2012 AN400, AN400A, DL1000 and GSX1300R motorcycles as well as the 2008 to 2009 GSF1250S and GSF1250SA. Also affected are the 2008 GSX1300BK and GSX1300BKA, the 2008 to 2010 GSX650F, GSX-R600, GSX-R750, VLR1800, VLR1800T, and the 2009 to 2010 SFV650 and VZ1500.
Posh Paul
IBA Member
RBLR 1000 '18
Armistice 1000 '18
RBLR 1000 '19
RBLR 1000 '22
RBLR 1000 '23
RBLR 1000 '24
Re: Reg/Rec Recall
« Reply #5 on: January 28, 2016, 21:36:35 »
It would be nice if the replacements were the SH847 series types used on the Veek.
Offline 650X
Re: Reg/Rec Recall
« Reply #6 on: March 08, 2016, 16:48:57 »
DVLA website shows a recall for the Camshaft / Valve problems that have been affecting US models. ANYONE HAD THIS DONE IN UK  YET ?
Offline bigpie
  • Site Donator
  • Bike: DL650
Re: Reg/Rec Recall
« Reply #7 on: March 08, 2016, 16:51:48 »
Mine goes in for it on Saturday. Lending my a fireblade from my mate while it is in.
Re: Reg/Rec Recall
« Reply #8 on: March 08, 2016, 16:55:07 »
Mine went in yesterday. Check this link out......
http://www.v-strom.co.uk/smf/index.php?topic=28271.0
