Givi engine bars
Topic: Givi engine bars (Read 1411 times)
Phil254
Bike: Dl650
Givi engine bars
January 15, 2016, 14:22:57 »
Afternoon all quick question do the bolts that attach to the engine for the bars need to be torqued up or just tight by hand
Cheers phil
Joe Rocket
Bike: DL650A L5, Kawasaki GPX750R
Re: Givi engine bars
January 15, 2016, 16:46:33 »
The bars are fixed by replacement (longer) bolts which support the upper engine mounting brackets. They are in the Manual at 35Nm and I'd have them torqued up to the same. I did with my Heed bars. HTH.
Phil254
Bike: Dl650
January 15, 2016, 19:38:07 »
Okey dokey cheers joe rocket
Gert
January 16, 2016, 12:11:34 »
I used copper-slip on the engine mounting bolts before torquing down. Makes it easier to remove at a later stage if required. Also remember to add a tap washer on either end of the bar spacer near the oil cooler - should help minimize any vibration
Phil254
Bike: Dl650
January 16, 2016, 16:08:11 »
Cheers gert
Givi engine bars
