2014 DL1000 Torque table
Topic: 2014 DL1000 Torque table (Read 9138 times)
loady1
Bike: 2014 DL1000, 2000 VFR800, 20017 R1200RT
January 09, 2016, 05:47:36 »
Can anyone please advise if there is a table of torque values for bolts. I am about to take my wheels off to swap OEM Bridgestones for Continental TKC 70s and would appreciate axle bolt/nut torques front and rear.
Downunder
Bike: Vee2
Re: 2014 DL1000 Torque table
January 09, 2016, 06:14:34 »
Check your messages.
Richmond, NSW, Aus
DL1000 ABS 2014
Downunder
Bike: Vee2
January 09, 2016, 06:19:55 »
Front axle nut 100 N-m (72.5 lbf-ft), front axle holder bolts 23 N-m (16.5 lbf-ft) and brake caliper mounting bolts 39 N-m (28 lbf-ft) - Owners Manual p 6-44
Rear axle nut 100 N-m (72.5 lbf-ft) Owners Manual p 6-46
Richmond, NSW, Aus
DL1000 ABS 2014
greywolf
January 09, 2016, 11:53:31 »
There have been problems with rear axle nuts across the entire model line. Stainless steel nuts on SS axles tends to gall or cold weld. What works is to apply anti seize to the threads and reduce the torque to 80% of the spec to make up for the lubrication effect. There have been zero problems reported using anti seize and 80Nm or 58lb-ft while dry installations to spec gets reports of problems.
http://www.stromtrooper.com/general-v-strom-discussion/23698-rear-axle-thread-galled.html
Lifebiker
Bike: BMW R1150RT
January 09, 2016, 12:04:18 »
Have a look in the handbook
SuMo
Bike: 2014 DL1000A4
Reply #5 on:
February 27, 2016, 02:41:20 »
Loady1 you'll find the torgue list starting on page 8 in this service data PDF file.
