Author Topic: Cleaning front sprocket area  (Read 2207 times)
Offline bosnjo
  • Bike: DL1000 L7
« on: January 07, 2016, 14:03:49 »
There is a big discussion on US forum about cleaning front sprocket and how not doing so can affect the operation of clutch slave cylinder and eventually lead to failure. After carefully reading through all the topic, I've decided to give it a go and clean mine. The point is, at 14.000 km's (8700 miles) the area was quite packed up with junk and I only ride paved roads on dry days. It could go up to 20.000 km's without cleaning (12.500 miles) but that would be a limit. The only thing I noticed on mine is that the push rod was completely "glued" to piston on slave cylinder and it is not supposed to.
Anyway, 10 minutes to remove slave cylinder and cover, 1 hour to clean with first removing big parts with wooden stick and then washing all with WD40 and paint brush (took 200ml of WD40) and then 10 minutes to reassemble everything.
Rode the bike yesterday and today and clutch lever feels much smoother.
DL1000 2017 white
DL1000 2014 red (sold)
DL650 2012 white (sold)
Offline Yoyo
Re: Cleaning front sprocket area
« Reply #1 on: January 07, 2016, 22:26:24 »
I did my Vee a month or two ago, I wasn't surprised how much crap was behind there, I was concerned about the clutch piston popping out but a cable tie held it in while I worked. Well worth doing the job
Offline bosnjo
  • Bike: DL1000 L7
« Reply #2 on: January 07, 2016, 22:57:00 »
Yes, I used cable tie too and just before installing it back, after removing cable tie, pressed the piston in all the way in to give me enough room to bolt it on. Perfect.
DL1000 2017 white
Offline petestrom
« Reply #3 on: January 09, 2016, 13:04:43 »
Think this is worth doing on any bike with a hydraulic clutch, had to do it on my bandit and XJR.
Pete
Make someone's day, it'll come back to you sometime.
