Hi all,
I have just had to free off the calipers on my BMW as the pads were dragging a bit on the discs.
I was warned off using spray brake cleaner by members of the BMW Owners forum because it allegedly damages the seals around the pistons. It's great stuff to spray over every now and again but for the life of me I can't see why a brake cleaner that is intended to clean brakes would be formulated with chemicals that actually damage parts of the brakes.
I didn't do a full strip of the calipers and on this occasion simply took then off and did use cleaner to blast off the crud.
However, I feel guilty! What I need is a cleaner that can be used every now and again (like the spray brake cleaner) but one that does not damage the brake parts.
Anything out there? What do you use? Gunk? Kerosene? .......I realise I need to keep lubricants off the pads and discs.
Thanks
David
