www.v-strom.co.uk/shop
Dog Bones how much difference do they make
Topic: Dog Bones how much difference do they make (Read 4917 times)
Cbx
Bike: DL1000 K2
December 13, 2015, 16:39:00 »
Standard suspenions links needed if any has a set kicking around.
Mine are 150mm between the centres could any tell me what the height difference is , it does feel very low .
greywolf
Re: Dog Bones how much difference do they make
December 13, 2015, 16:50:46 »
Yours are 10mm longer making the seat height lower by 28mm.
Cbx
Bike: DL1000 K2
December 13, 2015, 16:58:10 »
cheers matey
Theflyingscot
Bike: DL1000 K7
December 13, 2015, 20:03:37 »
I have a set of standard ones for a K7 Vee if they are of any use
Water is wet, Sky is blue. If you are after answers to any other questions Google it!!!!!
Cbx
Bike: DL1000 K2
December 13, 2015, 20:11:18 »
Cheers as far as I can tell from a parts search all the links are the same through the range , but if anyone else can confirm that would be great. how much would you like for them?
greywolf
Reply #5 on:
December 14, 2015, 02:36:50 »
The only model with different links is the Veek. All other Stroms use the same links.
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #6 on:
January 24, 2016, 13:24:52 »
I've just fitted what was described as a '50mm Jack up kit', however, the new Dog Bones are only 10 - 15mm shorter, can that be right?
The originals are 140mm which I believe is correct. Comparison below.
Bikers Campsite in West Wales
Visit the
V-Strom.co.uk shop
today!
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #7 on:
January 24, 2016, 13:49:45 »
I think I've answered my own question, I now have a seat height of 870mm, the standard being 820mm and I have read that a few millimeters change in the links can have a drastic effect on the rear of the bike.
Just the Centre Stand to alter now
Visit the
V-Strom.co.uk shop
today!
Sam
Reply #8 on:
January 24, 2016, 13:55:57 »
It works on a ratio of about 3 to 1 (or something like that!)
So 15mm difference in the dogbone equates to about 45mm in seat height.
Greywolf will be along soon with the exact figures
tallpaul
Tastier than the Barrow-in-Furness bus depot...
Bike: 2016 Yamaha XT1200ZE
Reply #9 on:
January 24, 2016, 14:00:43 »
It sounds right. The 25mm jack up kit I fitted was about 7mm shorter.
Fat Rat
Administrator
Bloke/Geezer/Fella
Reply #10 on:
January 24, 2016, 14:02:49 »
Visit the
V-Strom.co.uk shop
today!
greywolf
Reply #11 on:
January 24, 2016, 15:27:04 »
It's slightly under 3:1. It's not an exact relationship because the angle of the swingarm changes even though the the ratios between the swingarm pivot, link anchor and rear axle are fixed.
plumber02
Bike: DL1000-K8 wr450f
Reply #12 on:
January 24, 2016, 17:04:30 »
I've put these in and raised the forks by 6mm (
http://www.ebay.co.uk/itm/Suzuki-DL1000-V-Strom-25mm-Jack-up-kit-/120807555672?ssPageName=ADME:X:RTQ:GB:1123
) and it did make a noticeable difference , it just feels right, it turns in that bit smoother and its not in any way twitchy still with stock springs, mine had been lowered by I reckon 28mm with links pitch or 150mm it felt like a sportster and the cars behind were complaining about the sparks(18.5stone prob don't help either) , then I tried standard pitch 140mm felt grand obviously its factory setting to suit the masses, then I tried 133mm with forks up 6mm and it just suited me , you're never really going to get your knee down on one but if you've come from any kind of sports bike to me this was another worthwhile mod, just make sure you put a bit of grease down there because from factory I'd say they're as dry as a witches t.tty
Kayaker413
Bike: 2008 650
Reply #13 on:
January 25, 2016, 18:38:01 »
Hi Folk's,
Is this just to raise the seat height or does it make a decent difference to the clearance for riding offroad.
I am only 5"10 so don't need a higher seat for any other reason than not smashing my bash plate to bits
plumber02
Reply #14 on:
January 25, 2016, 19:10:51 »
basically its like increasing the lenght of the shock it does raise it up at the axis of the seat even more so the further back but if yo can picture it -its just changing the angle of the swingarm and also shortening the wheel base so at the furthest away point forward lets say the oil filter or downpipe I don't think would be raised up by all that much just pointing down a little bit more , I'm open to correction but I'd rather have less ground clearance off road than a steeper fork rake, beef up the plate or buy an early 90's cr500
greywolf
Reply #15 on:
January 25, 2016, 19:15:03 »
Raising links do both. The entire rear of the bike gets higher. It actually makes a Wee or a Vee more stable at speed. The slight change in rake and trail is more than made up by increased aerodynamic stability. The stock setup causes the front to lighten as the plastic ramp under the headlights causes front end lift. Lowering the angle of attack into the air helps with that.
plumber02
Reply #16 on:
January 25, 2016, 19:23:46 »
when Anthony Hopkins stuck his noggin up in the air on that world fastest indian yoke would it have been the same affect
plumber02
Reply #17 on:
January 25, 2016, 20:20:28 »
before n after from 150mm to 133mm pitch links , only thing is the side stand was cut n welded by a butcher so it looks bad and leans over way too much.
