Author Topic: Fuel line connector 2012 650  (Read 9147 times)
Offline kwarr
  • Bike: 2012 Glee
Re: Fuel line connector 2012 650
« Reply #20 on: November 14, 2015, 13:06:39 »
Cheers mate, I actually had to lean the tank to the left side (as much as attached pipe would allow) - that gave me a bit more purchase.
« Reply #21 on: November 14, 2015, 13:14:58 »
Definitely listen for the click on installation so it doesn't leak. Might be worth running the engine to check before putting it all back together.
Offline kwarr
  • Bike: 2012 Glee
« Reply #22 on: November 14, 2015, 13:19:26 »
Now that's (also) a very good idea - cheers
« Reply #23 on: November 14, 2015, 13:30:11 »
As a note.
If you get one of the sides to release but not the other it will not come off!
Both have to be released at the same time.
Offline Skyman
« Reply #24 on: February 08, 2017, 14:13:28 »
Hi, can somebody assist and share experience. When tried to connect the fuel connector with the fuel pump one of the o rings broke. There are 3 of them, green, black and beige + a plastic ring. They all sit in front of the blue clips on a pipe. Don't know what I've done wrongly! These o rings are not listed as spare parts nor I could find a complete connector as a separate part. Probably all comes as a fuel hose set at around EUR 100. Any advise? Thanks.
« Reply #25 on: February 08, 2017, 14:28:57 »
Working end clips are available. Combine them with fuel injection rated clamps and hose to handle 43psi and you can make your own. http://www.vstrom.info/Smf/index.php/topic,6105.270.html
Use clamps like the one on the left, not the one on the right.
Offline Skyman
« Reply #26 on: February 08, 2017, 18:16:00 »
Thanks Greywolf, in a mean time I managed to reassemble the original connector. Found one exact O ring in one box and somehow it works. But I will definitely look at your suggestion and get me those connectors. It's good to have them just in case. Cheers, thanks
Offline manxman1957@gmail.com
  • Bike: V-Strom DL650A XT, ST1300 Pan European, KTM 350 FreeRide, Triumph Trident T150V
« Reply #27 on: January 09, 2021, 16:40:13 »
Hello
Just a small suggestion to save your fingers, is to wrap a zip-tie around the blue bits to hold them in whilst wiggling everything else.
This has helped me a number of times, and if it gets easier over time, I have not noticed it.
Regards
Crazyhorse
Struggling like hell to disconnect the fuel line, then read this tip. Spot on, came apart like a dream - Cheers!
« Reply #28 on: January 09, 2021, 19:08:36 »
    A little tip I have learned is: when you pinch the two tangs together
on the fuel connector, push the whole lot further on and it will release the catches easier.
